Help with sensor
Jethro91775
Guys.
Any idea what this sensor is and were it goes.
ChrisBrand
Staff - Legal
If you can zoom out a bit we can tell you. In the alternative just look for a plug place in that area that has no plug in it and that one fits
Jethro91775
I checked. It's coming of the maf sensor harness. Will take a pic in a while. The cable is only long enough to reach the abs pump or throttle body
Here's the pic
Jethro91775
Low N Slow said:
Yep that goes into your maf
I see your airflow metre isn't connected with the filter?
It is connected to the filter.... were does that plug into the maf? And what is it.
Jethro91775
Low N Slow said:
Is your car e36 or e46? best bet would go onto realoem.com.....ther are diagrams of everything on it
e36.
Was on real oem for e few hors searching every diagram of engen bay. Couldn't find were it goes.
Low N Slow
Jethro91775 said:
e36.
Sorry man only familiar with e46.....will see if I can find anything for you
Jethro91775
Low N Slow said:
Jethro91775 said:
e36.
Thanks man.... Btw. Does the e46 have that sensor? Were does it go and what's it for.
applehero
I believe it is a dummy connector. Different engines may need different sensors. Cheaper to commonise 1 wiring harness over a number of engines. The plastic connector going into the end of the cable should have a part number on it...
Jethro91775
No part number on it. Just 3 letters if I remember correctly. And a small hole on either side.
