Rocco
Howzit Fanatics
I’m in a bit of a jam...I have a 05 e46 320D and the car has a very nasty vibration which sounds like something is touching the body. The vibration is worse when the car is in P or D but not moving...when it’s in N the vibration is not as hectic and audible. The vibration also varies when one turns the steering wheel from side to side at stand still. When the car is moving there is no vibration. The car did pop its water pump when it was on 159000km and soon after that the vibration started! I took it back to the garage that worked on the car but they have run out of ideas...well he mentioned that the belt tensioner and pulley needs to be replaced and is adamant its not the vibration damper but I have returned it numerous times already.
The car is on 174000 and is due for service in 1800km but the ride is so uncomfortable and unsettling I can’t deal anymore!:bangdesk:
Any ideas?
Any ideas?
