Dippies said:www.bmwfanatics.co.za/showthread.php?tid=9294
Hope this helps. The menu codes should be the same though. This will at least give you a idea where to go and look as well as the Fault experienced.
Good Luck.
tom88 said:does it only do this when cold, does it get smoother when warm?
if so then its your injectors and or HPFP.
George Smooth said:When I need to get my plugs changed thats the excuse I use and it works everytime. :roflol:
Chances are they will do your plugs first as the symptoms point in that direction. The injectors and HPFP might be done due to the recall as well.
Jacques24 said:George Smooth said:When I need to get my plugs changed thats the excuse I use and it works everytime. :roflol:
My thoughts exactly, they refuse to do it.............
Will see after a week of starting to replace parts and paying for my car rental :thumbs:
Jacques24 said:Mine is still in and they will look at the injectors today, I have abrand new F30 320i, I am happy, they can keep my car for another week, will let you know what the outcome is as well.
With which dealership is your car BMW135i?
Twinz said:There is a couple of threads on the PE exhaust. Also see my review here:
http://www.bmwfanatics.co.za/showthread.php?tid=1375
