Help needed-E90 xenon bulb replacement
Howsit guys.
So i just went to the shops and my warning light indicating that one of my bulbs needs replacing went off. Upon closer inspection I realised that it's my dim rings that are shot on the drivers side.
Firstly, is this easy to replace and can I get a whiter globe for this?
Secondly, the thought has gone through my head to replace the bulbs in my spots (yellow) with a whiter globe. And now is the perfect opportunity to replace the rings with a whiter globe along with the spot lights.
Can you guys advise and steer me in the right direction to someone that can help?
I am based in Centurion.
DieselFan said:
Why didnt you just get LED bulbs from Vsomai?
I got the globe before being put in touch with Vsomai.
But considering still getting a set from Vishal.
Does anyone know how to replace this globe cos after sukkeling and banging my hands, in the lil bit of space that BMW have given, for an hour this afternoon I gave up and closed everything up?
Kish2604
Administrator
Do a search on the forum, twins had put up a DIY on the e90 to change angel eye globes...
DieselFan
Thats for an LCI, prelci halo bulbs are in a different location but I'm sure the process of getting there is pretty much identical.
