nicwes said:Getting nowhere with the BMW mechanic. Is there anyone I can take it to in JHB to look at and maybe replace? I can get a new fan at CR Auto in Pta for R2280. But they don't fit it
Mamba said:nicwes said:Getting nowhere with the BMW mechanic. Is there anyone I can take it to in JHB to look at and maybe replace? I can get a new fan at CR Auto in Pta for R2280. But they don't fit it
LZ maybe?
It is not that difficult to fit, you just need the correct tools...![]()
moranor said:to change the fan in literally a 5 min job... 2 screws on top and unclip the electric connectors and slide the fan out... oh you have to take the airbox snorkel off with is anther few seconds...
the only problem is the screws are torx so you need the right bits...
Mamba said:moranor said:to change the fan in literally a 5 min job... 2 screws on top and unclip the electric connectors and slide the fan out... oh you have to take the airbox snorkel off with is anther few seconds...
Thanx for this, I had to strip more than this bits on the E66 to get it changed ..![]()
nicwes said:Okay. Spoke to the guy at Park Motors myself. It is a resistor in the motor that has malfunctioned or something. He says that the WHOLE unit has to be replaced, the resistor can't be replaced seperately. Can anyone confirm this for me? (I have no idea how these things work)
He also told me that the fan does come on, but only at the first speed, and as soon as the car heats up, the fan doesn't speed up to cool the engine down, and that will cause S H 1 T when driving in the city. Now as I said earlier, I have found an electric fan (which it is) in PTA West for R 2280. The guy I spoke to said it's a new fan :thumbs:
The dude in Welkom is looking at a second hand fan
Will talk to my dad to see wat gan vir wat
IF I buy the fan in PTA west. Is there anyone close I can go to to fit it? Maybe a fellow fanatic or fanatic's friend that won't charge me an arm and a leg? I don't expect it to be done for free
:ty:
Sankekur said:nicwes said:Okay. Spoke to the guy at Park Motors myself. It is a resistor in the motor that has malfunctioned or something. He says that the WHOLE unit has to be replaced, the resistor can't be replaced seperately. Can anyone confirm this for me? (I have no idea how these things work)
:ty:
If you can only get one in PTA then you can come by my place and I can help you with it.
Have you tried goldwagen? I know CR auto to be really expensive.
frikkieh said:To fit the fan is literally 5 minutes work. Side cutter to lift the expanding rivets and a torx bit to remove one screw (I slotted mine with a hack saw so a normal flat screw drive works just fine - had no Torx available when it broke down once).
Here are the items to remove to loosen the fan and remove it:
Sankekur said:@nicwes: I am in waterkloof in pta. Let me know what your plans are.
