M3_e36
kish said:Yes, cleaned MAF
still holds back sometimes
Damn i wish i can find the problem, she runs fine when hot
hey i know this is a old post but mine does exactly the same cant figure out what it could be and it only happens when the oil is not fully warmed up, the car picks up no codes iv replaced the fuel filter but just at about 5000rpm it cuts thens pull slowly and if i change gear at that cut the next gear will cut 1000rpm lower but the minute the oil is fully warmed up it runs all the way to cut out, have you perhaps found the cause of it or any other clues what it could be?
