Salt said:
OK...need some advice. The car went for a full technical and diagnostic today at Dekra along with roadworthy. The following errors were picked up on the diagnostic report. I don't know how it works - wondering if these can be old alarms? I had the car checked out by a fam member this evening and the AC and sunroof work fine so does the radio. He did install an after market 10.2"touch screen from vwtotoyta touch screens...they say its plug and play and doesn't cause any issues. I am getting the original screen with the car. Not sure if that could cause the head unit error? Car is still under motor plan. Wesbank requested the inspection so not sure what they are gonna say about the diag report...I don't know if those are common alarms that can just be cleared...old ones that were never cleared before etc. The car was at BMW for a service 1 Aug. And then there is a small gap in the dash on the drivers side...that supposed to be like that?
CANT figure out how to post pics hehehe...got them on a google drive and shared but doesn't work?
Use tapatalk to post the pictures.
That said, I doubt Dekra look at the logged errors. From what I have seen, they actually do physical testing. So they will check every light, and see that it goes on when it should. They physically do battery test, and they let me know a battery was going to die..and it did. They do physical inspection on the body inside and out ect. They really do great testing.
Dont worry about the error codes. If they about the radio and sunroof, you can tell Dekra you will get it fixed and that you don't think that a minor issue like that should stop the deal, especially if they actually work.
Oh I have an aftermarket radio in my E46. Rheingold ISTA-D says my radio is faulty, but thats because the after market radio doesn't report or react to reading. So it just looks missing.
