HELP Again, weird noise in or around exhaust??
e46320i
Medres helped me out on my previous post (thanks!) so Im hoping someone could assist me here:
:banghead:
My car has developed the weirdest noise it started about 5months ago in or around the exaust at idle only. It sounds like a ringing noise but with a metallic vibration no one else hears it or knows what it is has anyone experienced this and had it sorted out?? please give me your thoughts!!???
Peejay
Events Organiser
Had a similar issue on Friday. Turned out to be one of the supporting brackets on top of the exhaust had broken off.
riaanm03
same happend to me, replace your cats or remove them before the insides get stuck in the exchaust pipe, this will block the air flow and cause more problems
e46320i
Great! Good excuse to get rid of the cats I will also check the heat shield and mounting brackets to see if these are the culprits.
