Handsfree kit e90
Noob
Hi all,
I have a 2010 e90 320i BMW with Idrive but no bluetooth or pre wiring for bluetooth..... So is there any way to still use the existing steering wheel and idrive screen with an aftermarket kit? Only concerned with making and receiving calls....
VIN number- wbapg56080nm21401
Thanks in advance.
boost3d
You can fit an aftermarket device like the "Parrot" which is compatible with the existing steering wheel controls...
Lizzard
Hi Noob,
You don't have to give the complete vin number ever, ONLY the last 7 numbers ..... in your case NM21401.
The best person to chat to is Gert (our Guru :praise:), you can find him on the forum ......search Ratslaaf@obdworx ...... chat to him and he will tell you if or not you can do that. He also retrofit things if it is possible. :clapper: He does the OEM way or you can go the root Boosted said with an aftermarket bluetooth
Hope this helps. PM him
beezo003
Howzit Noob
i got a used Parrot 3000 R700,let me know if interested?
if you like you can whatsapp me on 072 971 2042
Noob
Who can help me with a mobridge system in kzn? I will require coding as well but seems this system will work perfectly?
