GlassyLite Headlight Restoration & Protection Kit
Legacy
No idea about the product but its Autostyle so usually means its rubbish.
I can do the restore for you for a packet of chips and a coke. Its two hours of not so much effort.
Caddy101
Where are you based?
KSINGH
seriously how much do you charge or is there a diy i should google?
Legacy
I'm based in PTA and in all seriousness do it for R150. Its as simple as wetsanding the light covers down and then just polishing the sanding marks out.
ClassicB
Does this process remove the pitting caused by stone chips?
Legacy
If the lenses are plastic yes, if they are glass probably not I've never tried.
ClassicB
Thanks! was wondering about glass. the ones i have are still ok, but i have seen some that look awful
Id bet you can make the same kit for less money with better polishing compounds... maybe crazy detailer has something...
Legacy
Its more about the technique IMO, you can still screw it up with the best products.
KSINGH
I go thro there daily. You did not talk about the uv protection?
for sure but paying more for inferior products never makes sense :rollsmile:
naickers
@Legacy....Do you want to do a groupon special... I would certainly like mine done as well, E39 540i/6
maybe we can make a day of it, bring and braai, beers....
