discussion G01 X3 Help
momoPike
Hi guys,
Happy New Year and with it some annoying problems.
1. One of the car keys has gone missing and while k ow you can get a cheap dupe; is BMW the only place to get a new key coded and the one removed?
2. Sometime over December the window shade holders for the rear doors broke. No idea how but I’d like to get it fixed since the window shades are otherwise useless now.
Any tips for the problems listed? I’m in JHB but happy to drive anywhere in GP to get it sorted.
Note : Yes I do have insurance on the keys; trying not to claim since I just moved insurers tbh
m0lt3n
Did youcome right on the key? I also lost a key, was thinking of trying the Aliexpress keys and code it.
AshG108
Hi guys,
Try get a blank and recode it for the key.
wrt to your window blinds, how did they break as what part. Is it the holder that broke. Plastic welding can fix that for you easier if that is the case.
momoPike
So an update. Gustaf’s Garage recommended an Auto Electrician and I got pricing. R4k for a key and coding. Will be going on Monday since it apparently takes a while.
As for the plasti welding, been watching some videos and going to try do it myself since this seems like a weird problem to have
AshG108
Where you based?
The videos are quiet self explanatory but do use a staple or metal piece to add to the pieces for the strengthening of it.
Good luck, hopefully it works out bud.
momoPike
For those following; in a kak turn of events I now need both keys for both this and the mini.
X3 full set incl labour is R30-R35k.
Mini is R15k for a full set incl labour.
Increase the cover on your policies gents
Jaws
Increase the cover on your policies brea
House robbery and they took the keys?
modocrat
But how...? 😕
momoPike
Finally got sorted. Might be one of the few people in GP able to do it. Got a key programmed for R12k. Still need to get it cut but at least the car is moving again after almost 3 weeks.
Was told only the pre-facelift G01 are doable. G20s not so much
momoPike
who was it that sorted this for you? You had to get a brand new key and coded it to the car, without removing the FEM?
They removed the FEM onsite and coded the key as well. Private Locksmith but he does ECUs etc apparently.
I’ll ask him if he is comfortable with me posting his details here but you ca always PM me
