Foglights fitted - DIY
J
Jandre
Ironblaze94, I got the switch from Motorem in Parow industria. You will have the 1 button switch next to the headlight switch, you pop that out, and plug the two button switch in. The car is pre-wired for it, so you will have no difficulty.
If you run your finger along the bottom edge of the airvent/ switch, you will find a star screw. Take that out, and the whole vent with switches will come out. You will then be able to disconnect the wireplug, pop out the 1 button switch, pop in the 2 button switch and voilla.[/align]
plonkster
Can't really decide. My car looks a little unfinished with the black plastic inserts instead of foglights... however, I can't remember the last time I encountered serious fog, and I really hate it when people drive with their foglights on all the time, not so much because of the front foglights, but because of the bright red one at the back.
So installing foglights will be a cosmetic add-on for me. Wish I could get "fake" ones to just sit there and look beautiful :)
Should probably also invest in a good set of sunglasses :p
J
Jandre
I did mine for cosmetic reasons only. It just looks so much better.
blaze94
Yeh i just shorted the 2 connectors at the time so the fogs are on permanently. Thanks for the info!
