2LV2 said:
OK. Let's call it the fastest E46 Touring. I might have been a mite over-excited about the idea last night.
Turbo, that's a given. Specs? 1.5 bar. Mmmmm. New fuel system and management? Any advice?
Rods? Pauter?
Pistons? Any advice on the specs?
AVgas? Ok.... But I still want to use it during the week as well. Separate tank for runs only?
And we haven't even started on the suspension yet. OK. This is going to be a long term project......
Pistons = 84mm JE
rods = ARROW 600hp / rod
no management needed, DASTEK UNIQ+ will do every thing
550cc RC injectors
T4 exhaust housing AR75 compressor housing
custom manifold
Cooler to fit behind full length of bumper
EXCELL dump valve and waste gate
9bar combi fuel pump with surge tank
custom turbo manifold
DASTEK boost controler
silicon hoses and bends, stainless plumming
small aditional oil cooler
Custom Norbrake button clutch will be good for up to 1.1bar boost
DASTEK chip you can choose between 5 different maps each of them can have a different boost level and select all with the push of a 5 channel dastek map switch! dasek boost controler can adjust boost from 0.2 bar - 3bar!
