Fastest Touring
2LV2
i want to build the fastest Touring in the country. Could the Gurus give me any advice? I have a '03 E46 325i Touring. She has an SMG box and is still pretty tight. :)
Coisman
Administrator
:cursin: so you wanna beat my 325i Schnitzer do you...
it's ok :pimp: no worry, why not keep it stock, and pimp it out into a "love wagon"
Put some furshag carpet in the back, and a disco ball in, and your set.
STREETRACER
+1 on that turbo conversion! 325i double vanos is good for 300wkw on avgas and 1.5bar boost!
But rods and pistons are a must on that baby boost!
2LV2
OK. Let's call it the fastest E46 Touring. I might have been a mite over-excited about the idea last night.
Turbo, that's a given. Specs? 1.5 bar. Mmmmm. New fuel system and management? Any advice?
Rods? Pauter?
Pistons? Any advice on the specs?
AVgas? Ok.... But I still want to use it during the week as well. Separate tank for runs only?
And we haven't even started on the suspension yet. OK. This is going to be a long term project......
STREETRACER
Rods? Pauter?
Pistons = 84mm JE
rods = ARROW 600hp / rod
no management needed, DASTEK UNIQ+ will do every thing
550cc RC injectors
T4 exhaust housing AR75 compressor housing
custom manifold
Cooler to fit behind full length of bumper
EXCELL dump valve and waste gate
9bar combi fuel pump with surge tank
custom turbo manifold
DASTEK boost controler
silicon hoses and bends, stainless plumming
small aditional oil cooler
Custom Norbrake button clutch will be good for up to 1.1bar boost
DASTEK chip you can choose between 5 different maps each of them can have a different boost level and select all with the push of a 5 channel dastek map switch! dasek boost controler can adjust boost from 0.2 bar - 3bar!
andrewbuch
Just subscribed to this thread, would love to see this build from start to finish.
For starters post some pics of the car :)
2LV2
Rods? Pauter?
Pistons = 84mm JE
550cc RC injectors
custom manifold
Awesome....... Thanks for the very comprehensive list:shocked:
Where do I start....:thinking:
Daddy gonna get all the Xmas prezzies this year. :)
For Sure.......
Watch this thread:)
