cOlDFuSiOn said:
Indeed I think if one gets between 50-70k from the fronts it is good. Anything between 20-50k on the rears also depending on how one drives. I have been taking it easy lately so things last hehe.
One should play with the pressures to see what works. But sidewall wear does tell me the fronts are a bit under inflated. The rears always wear on the inside sidewall thread due to the negative camber but the fronts should not.
Agree, tire pressure has to be adjusted to ones needs and the roads we drive on.
Front 2.4 /Rear 2.6 - should be perfect.
cOlDFuSiOn said:
Latest prices I have R8k for 2 fronts BTW. This is with Mintys Sandton. BMW was around R8.5k for them.
I doubt you will get them cheaper in Jhb, I can get the for around R3750ea in Vereeniging.
