F30 320i bigger turbo options
SumzGP
Howzit
Any ideas for bigger turbo on a 320i without having to do internals...could anyone guide on what's the limits I could push and where I should stop?
Out of plan
Straight six
How much power you aiming for?......
320i=135kws
328i=180kws
You can just get a 328i.....its a better compression motor, better platform if you want to go even higher with the power.....but then you can just get 335i:rollsmile::rollsmile:
TurboLlew
I am not sure anyone has done this on a 320i before. I am also skeptical of the cost vs. benefit vs. reliability given the limitations you might encounter with a proper BT setup on the N20 platform, primarily the block design, compression ratio etc. You might end up spending more money than sourcing a nice 335i...
What is your objective? Just more power? Have you driven one with JB4? What did/didn't you like about it?
akash
I remember seeing a thread of a F30 320i that was flashed for more power and eventually the car started smoking
sash
There was one guy who modded his f30 at xcede..., a lot of mods saw it make some decent figures...
cOlDFuSiOn
IIRC they can push around 240kw with some tuning and mods. How long it will last is but a guess? Not too many modded ones around, most guys get a 135i hatch, they are good value for money power wise ATM, perhaps think of that.. As it has been mentioned :=):
SumzGP
Thanks gents
Wanted to keep the car, there aren't many modded 320s apart form JB and the minor mods
Going to have to think about the 335 perhaps
tman
There was a thread on the forum about this f30. It was close, if not more than 200kw.
Personally I would do Software plus some minor mods to get more punch as apposed to a big turbo build.
Sent on the move via Tapatalk
