will the above rims fit onto an E90 Lci without touching, rubbing or sitting too much inside the wheel arch as i am assuming that the F30 has a wider track?
that's the tyre size.
You need to confirm with wheel size. Offset is important. F30 has a higher offset than e90. The wheel will sit further in, but best to confirm with offset.
