msm
I'm experiencing (another) strange problem after my decat. Before I spend some money on what I think is the solution, I thought I'd post the symptoms in case anyone experienced similar.
Firstly, some background: Had the stock header replaced with 328i catless headers and had the centre cats replaced with a normal "muffler" box. Noticeable performance increase above 3K RPM. Car pulls much more cleanly to the red line.
Anyway, here's the issue: At 120K/Hr to 130K/Hr ONLY, I'm getting a "droning" noise with some vibration coming through the entire car. The closest I can describe it to, is like when you drive on the freeway at high speed and open one of your back windows - it almost feels like that same buffeting noise/feeling. It's also most noticeable in 5th gear. If I drop to sports mode and change to 4th or 3rd it goes away. There is a slight raspiness in all gears at around 2.5K RPM, but it's not that at 120K/Hr - it's something very different. Alistair (Powerflow) suggested that it could be the back OEM box failing, due to the additional flow coming out after the decat. He mentioned something about the stock box having fibreglass bits that could be causing this.
Before I replace the back exhaust boxes, any other suggestions as to what it could be, as it is extremely annoying :banghead: At speeds below 120, it is fine - slight raspiness only, but I can live with that. At 120, it is driving me crazy :cursin:
