Engine swap, wiring advice needed
allanzaloumis94
I have a BMW E36 325is and I'm swapping my engine to an E46 M3 engine. I'm looking forward to completing this swap before summer is done and I'm serious need of advice to this conversion work.
I'm in need of wiring advice ASAP
Sent from my SM-G900I using Tapatalk
Ratslaaf
This won't be easy at all if you also planning on using the DME off the E46 as well. You might be better off using an aftermarket DME to get it going.
Gizmo
Banned
Import an aftermarket ecu designed for the S54, will save you alot of headaches and still have the option of fiddling with settings to optimise future upgrades.
How are you going to get past the sump/subframe clearance issue?
allanzaloumis94
Sorry i left for a bit, I'm not sure on how it ought to work. Because i assumed the e36 m3 engine and e46 m3 sump were positioned the same.
Do you know a place I could purchase an aftermarket dme?
