Damaged water pipe:
Then I had the turbos off, just some pics of that:
all the parts out on the floor:
Then it was time for the removal of the wastegates You can see there was something done to the rear turbo, but was not replaced with the upgraded ones like I asked:
Then cam the front turbos and it's wastegate was basically seized up:
Then I noticed the exhaust side of the front turbo was a little wet:
Removed the cores so I could take them to Enthusiast garage(Afzil) for a recon:
Rear one was not bad:
Then eventually my parts from turner motorsport arrived:
Aswell as the reconditioned cores:
Post to be continued......
After the time was car was standing for a while while I was waiting on the parts I noticed some oil from the gearbox, but we will get to the gearbox in a while:
Then I also recieved the heat shields that was missing when I got the car but you could see the level of skill used to remove them, I also received a brand new coolant hose together with the heat shields so that was sorted at-least:
Then just some picks of installing the new wastegates and bushes:
and the turbo's was ready to go back on the car:
I then had to source a new rear heat shield for behind the turbo as it was not with the shields returned to me, and also note that they were not installed when I go the car, manage to find one at a scrap yard:
and then it was time to re-install the snails:
Used new bolts as far as I could:
And then the car was back on the ground for the first time in about a month:
I also replaced the sump gasket while the subframe was removed and after the car was on it's wheels also did the tappet cover and the oil filter housing. I did find some weird gasket maker like stuff on the filter housing:
Then I received some picture of this car:
I was very keen to trade it in as it had some mods done already, but after a test drive I realized just how much options my car has that this one did not so decided to rather give it a skip.
I also drove the car to Durban and back over December and must say it was well behaved and did not give any issues, maintained a average of 11km/l so was quite impressed.
Then cam time for a gearbox oil change and ZF gave me some bad news:
Adaption values are out of spec and gearbox will have to be reconditioned, this was obviously not in my price budget so I started looking for a second-hand box, I might have found one and the might happen within the next month.
Then last week Friday I decided to get a baseline dyno run done:
I think for a stock car this is not bad at all and a few minutes after the dyno run I also installed some DCI to the car:
Will do another run after I have done some more work to the car, and the gearbox, as that is the next thing on my list before I am allowing myself to do any further mods.
So there you have it, My last few months in a nutshell
KPM_330 said:
Pictures aren't loading bud.. :fencelook:
Fixed I think :ty:
michael.joseph said:
This is just heartbreaking to see.
So sorry man
:blueCry:
Yeah man, this just reaffirmed my theory in "If you want it done right, do it yourself"
I know there are good mechanics out there, they are just becoming more scarce.
Also this guy calls himself a land-rover and Jaguar SPECIALIST, looking at the gasket issue I think I know why land-rovers leak oil:skit:
