E90 LCI 320D rear bulbs
beamo
Just an fyi
I recently had a warning on the dash for a light that went out.
So I went into the menu and on the warning pressed and held the BC button on the stalk and it showed the error code which was CCID-134 (Right rear brake light bulb failure), so I phoned BMW and they quoted me R600 for 2 LED bulbs :cry:
Went to Goldwagen, R8 a globe, same as original :rollsmile:
Very easy to replace, open trunk, remove cover, light fitting has 2 clips, twist and pull put bulbs, replace, done.
Some Codes:
CCID-134 : Right rear brake light bulbs
CCID-135 : Middle brake light(On top of rear windscreen)
CCID-136 : Left rear brake light bulbs
Note that the warning shows up when a bulb is out or is about to go out, with mine I could barely see that the bulb was out and it was only apparent when replacing them.
