e90 drop hats on e36?
ver328i
Hi gents
I need to correct the way my car sits now and very fast...Seems with the koni springs and 17"s up front the car looks as if its going uphill permanently. I need to lower the front by about 10mm or so.
will e90 drop hats work? I know the e30 guys use this to get a little lower...
This pic actually makes it look better than it really is
Lee 328
Howzit have the same problem , spoke to the guys at Speedshop they say the cabrio is heavy in the rear , so standard springs for sedan will result in this , they recommend eibach springs designed for cabrio which have strengthened rear springs
Costs R4800
, let me know if you find a cheaper fix , cheers
ver328i
I Have Koni Springs and the rear is quite firm.
I'll give the e90 drop hats a go this weekend...apparently its R250 a side
Will post the results if this works
** Nice looking car you have there Lee :coolShake:
DROP IT - ZN
Costs R4800
StableRide or SpringRite :coolShake:
Make new springs according to how you want it, They will also sort out the sagging right side and even out the car
ver328i
Drop hats are like R232 each at BMW but theres no stock in cape town and i needed it for the weekend!!!:smashScreen:
