E90 Control Arm Bent (pothole impact) - Heat Straightened
MM6
Going out on a limb here. Keep the guns lowered and uncocked.
The missus looked down whilst driving and hit a big-ass pothole. I established this whilst driving and all steering warnings lit up. Steering was also well off centre. Called my beloved with an indirect question: so how big was the pothole you hit? She is a sucker for honesty: I am so sorry (along with long excuse and more apologies).
Took it back home and found the left lower control arm was bent. I got a price on a replacement from BMW and an estimate to fit. Not crazy amounts, but I wondered if a simple heat application could save my fear - nay terror - of potholes. So I placed the control arm on a jack (with the weight of the car 'left-front' acting as its own 'press'), and gently applied heat from a small canister type blow-torch to the area in red with greater focus on the red arrow - I applied heat for a few minutes, carefully monitoring any bending movement. The control arm bend slowly straightened up ... near perfect.
Sent the BMW in for alignment and assessment and established the toe and camber were slightly out, which was corrected.
A concern of control arm integrity (internal compromise) is reasonable. A repair of this nature evidently carries risk ... I await an avalanche of criticism :)
In my defence, the wheel alignment company is going to repair my slightly buckled rim ... they use heat (just saying :) ) 1615290012209a.jpg
30cm ruler for perspective ... bigass pothole for sure
1615289853009.jpg1615289852993.jpg1615289853016.jpg1615290012214.jpgScreenshot 2021-03-09 141043.png
husaindindar
Yips.
You're in for criticism.
From myself first, I guess...
It will now be more prone to bending at the slightest impact.
I replaced a lower control arm last year on my E90. GW sold me a Meyle HD for R1200.
NBN
no disrespect or criticism , just something to make you ponder....
When it comes to safety critical equipment, such as suspension, tyres, brakes etc, does it make sense to always go with the cheapest option, when the cost might be , putting the life of you or your family at risk? To the naked eye, that repair might suffice but what if the heat has now made the whole part brittle or unstable etc etc?
