E90 Alarm dont disarm
APG10
Hi Guys
Please help got this really frustrating problem with my E90. When I lock the car the key fob, the doors will lock and beeping sound will go off. So if I want to unlock it again, only the doors open no beeping sound. If I start the car the alarm goes off.
So I have to play around open and close all doors the boot, press the key several times before it actually disarm the alarm (very embarrissing).
What might be the cause to all this?
:eek:mgwaiting::eek:mgwaiting::eek:mgwaiting:
Solo Man
I would start by reprogramming the key/alarm. If i remember correctly there is a sequence dictated in the owners' manual how to do it, otherwise some one on the forum should be able to help with advice.
APG10
Thank men. Well still luck on the forum but will check the manual as you said. :ty:
FerdiBotha
Why does your E90 make a beeping sound?
They do not normally do that.
You probably have an aftermarket immobilizer or alarm system fitted that is now acting up.
KiLLRoYza
Yea, from what I understand E90s can't have beeping for locking and unlocking programmed so you probably have a aftermarket immobilizer installed. A auto electrician should be able to assist with that.
S1NGH 911
That is not correct, E90 can have the beeping function coded in, I have had it done on mine way back in 2013:thumbs:
SubLoaded
Resident Derailer
I have it on my E92 as well. Beeps on lock/unlock. When the siren stopped working - it had stored an error code which I picked up via the scanner so it's definitely native.
FerdiBotha
Interesting.
I’ve never actually heard an E90 beep when locking/unlocking.
Learnt something new:thumbs:
S1NGH 911
FerdiBotha said:
Interesting.
Kish2604 coded it for me using NCS expert if I remember correctly
Danny2
correct the beeps for locking and unlocking the car can be programmed.
E82 also doesnt beep by default. I have coded my own
KiLLRoYza
You learn something new every day. I've never seen it either
