DarrylvanNiekerk
Good evening,
I have been battling with a persistent misfire which I just cannot nail down.
If I start the car and spray a jet of water onto the exhaust as the branches are heating I can see the misfire is on cylinder 3.
I have swapped coil packs, checked spark plug gaps, swapped injectors and the misfire stays on cylinder 3. I have cleared faults and there are no codes present.
I can't see any damage to the coil plug or wires and the brown plug wire is grounded.
The only thing seemingly left is that signal isn't being sent by the DME or is there something else I am possibly missing?
When I pulled the plug it was wet with fuel. There are no compression issues.
I have been trying to figure out the issue for the last few days and now the half orange check engine light has come on.
Any advice would be greatly appreciated.
