E90 320i decat
PaulWW
So my e90 has 140k on the clock and has started farting white smoke. So the dreaded valve seals are going to be done. Just deciding on whom to take it to.
Now, what would be the benefit of a decat at the same time?
My logic tells me that the cat must get clogged if oil is being burned.
Thoughts?
PaulWW
that_guy_Ettiene said:
Speak to John (BMW Leo Hease Hatfield).
Awesome pricing on valve steam seals replacement.
From my S7_Edge
Sadly I am based in Cape Town
momo1
Yip will definitely clog up your cats.
I had mine removed on my old 120i for about R850 2years ago.
really helps the engine breath better, changes the tone of the exhaust and avery very slight up in power, with consumption also going down about 0.5l/100km , I thought it was worth it.
GoCart
momo1 said:
Yip your cats will definitely clog up your cats.
Many cats :=):
If you can get it done cheap, and in SS, then do it, there will be a ever so slight improvement in efficiency, but doubt you will even notice.
PaulWW
My thoughts are that the clogged cat will restrict breathing. Effectively causing back pressure
GoCart
I agree, but are the cats clogged?
PaulWW
No idea. Just applying some logic.
Will chat with the mechanic
GoCart
Logic is always good.
My experience is that cats don't clog easily, I know of diesel cars with 400,000Km+ running original exhausts.
I would say though, if you have been running your car for a very long time with the busted seals, never giving the exhaust time to heat up properly, there might be a possibility of some clogging.
PaulWW
Let's see what SMG say about it. They are busy doing the valve stems and oil separator at the moment
Neve24
Hi PaulWW,
What did SMG quote you for the valve stem seals?
Sent from my LenovoA3300-HV using Tapatalk
PaulWW
Valve stem seals, sump breather, leak on oil filter housing, leak on tensioner pulley = R11.5k [LOUDLY CRYING FACE]
PaulWW
Neve24 said:
Hi PaulWW,
Sorry did not copy you on my reply.
