Ralf*
herco said:raise:
raise:
raise:
That is very similar to what I want. Might even prefer that above the 335i look.
How much would that roughly set one back Ralf? If I already have the motorport bumber.
it depends on whether one attempts to retain and work around the existing box which is only a single output, ideally the rear box is replaced with a "one in two out", then the one out is attached to a single Y-piece tailpiece, and the second out from the box is used to run a pipe across to the opposite side, and then dependant on space constraints, either two single tailpieces or a Y-piece to achieve the 4 pipe look (functional)
