E90 320d 2012 - Warning Ligts advice needed please
nicwes
Hi all
My car has started this thing where after a short time driving the TPM, traction control and ABS lights (all yellow) come on. I get a fright everytime it happens because it deactivates the cruise control at the same time. It has been the cause of a very close call in the rain for me as well.
After I've stopped for a while the lights go off right after I drive off again and all is fine for a bit.
Does anyone maybe know what the cause is?
Thank you in advance
Sent from my LM-G900 using Tapatalk
Danny2
this issue could be caused by a few different things like bad battery, wheel speed sensor.
Best would be to get a diagnostics done on the car to determine what fault is coming up
nicwes
Thanks! Battery was replaced about a year ago. Will check if I can find someoe to do diagnostics where I live and while the lighrs are still on
///Avi
I had this issue on my vehicle last year. It was a wheel speed sensor. Could be a damaged cable but most likely it is just the sensor.
ray.dummer
had this before on a e46, also went through everything and at the end of the day it was a excessively worn inner part on my one front tyre. Replaced and all good
Sent from my SM-A515F using Tapatalk
SubLoaded
Resident Derailer
Probably wheel speed sensor. You will notice the speedo drops to 0kmh in motion at times as well iirc.
