E90 320 D '11 M Sport
IanA
Hi all,
I recently had the FMR mod replaced (windows/lights/indicators weren't working) and since then I have been getting the yellow service light pop up on the dash on startup. I checked the codes and it's CCID 415. It re-appears erratically (not on every startup) after resetting the code.
1. The only addition to the car is a tracker system otherwise it is 100% stock. Could this tracker possibly be draining the battery?
2. The car does less than 50km's a week - Should I invest in a Trickle Charger?
3. Must the battery be registered after the FMR module is replaced?
4. Could you recommend someone doing diagnostics in the Northern Subs
Thanks:thumbs:
momo1
IanA said:
Hi all,
Thanks:thumbs:
I think Gert from OBD might be able to help you..
IanA
momo1 said:
IanA said:
Hi all,
Thanks:thumbs:
Thanks, his details?
I meant *FRM
momo1
IanA said:
momo1 said:
IanA said:
Hi all,
Thanks:thumbs:
I meant *FRM
https://www.bmwfanatics.co.za/archive/index.php?thread-66939.html
IanA
momo1 said:
IanA said:
momo1 said:
IanA said:
Hi all,
Thanks:thumbs:
I meant *FRM
Anyone in CPT?
Mamboza
Had a similar issue last week on wife's x5. Just repaired the frm module and was getting battery discharge error. Bought a charger from midas for R450.00 and charged overnight. Problem has disappeared...no coding was necessary.
