trinomic
Hi all,
About a month ago I got this warning....
• CC-ID 415 – Battery Discharge Rate High
It disappeared after about 2 start ups and then popped up again yesterday and its disappeared again now. I dont have a multimeter to test but I've used the hidden menu options to monitor the voltage.
At cold startup this morning: 14.8v
Testing turning on lights, radio, ac dropped this slightly to about 14.4v
Driving for about 20 mins with radio and lights on it fluctuated between 14.0 and 14.5v
At my destination i switched off and it slowly dropped to around 12.1v.
Does it seem like time to replace the battery or should i be investigating what could be causing the high discharge rate?
Lastly, this is the battery currently installed. I am not sure when last this has been replaced. Can anyone confirm whether this is fitted with the IBS?
