E85 in my 135!!!
EwMPS
Protea/Rolf Chemicals, there is one in Germiston as well, close to the Athletic stadium, can't remember the name..
Executer
Inactive
Protea Chemicals, they not sure what E85 is, but they can sell you Pure Ethanol, E95/5 @ R12.50 p/kg, though liquid form, 167KG`s is the drum sized with R130 drum deposit
Twinz
Forum - Support
E85 and e95 is the same thing.
Please remember guys you need a special conversion/mapping to use ethanol plus you need to be advised on the proper mixing.
Your car will go kaboom if you just pour it in your car...:nono::nono:
Chemical companies including Crest/Protea knows nothing about mixing ethanol in cars.
Twinz
Forum - Support
Executer. Yes, i agree that price is too low. It must be something other than ethanol they selling
Melinko
Thank you for the input guys, I will try and get a hold of the above mentioned companies. @ Twins, I am looking to run E30 - E40 at first to get a feel for it, I have the flex fuel wires installed so I should be good for E50 down the line. :=):
Twinz
Forum - Support
No need for progressive (e's) if you have the flex fuel.
Take 8 liters of ethanol (e95) and mix with 12 liters of pump fuel and put the car on map 5 and have fun. If you run meth put it on map 3.
Once that is finished...increase to 9 liters of ethanol e95 and 11 Liters of pump fuel. Dont increase the ethanol to more than 9 liters unless you have the BMS flash installed.
For an even more aggressive mixture:
Premix the pump fuel with NF concentrate or use 98 or 100 octance racefuel instead of pump fuel and mix those bad boys with the ethanol as per my above suggestion.
Lastly, ethanol does not mix well in the tank. Consider mixing it before pouring it in the tank.
