Protea Chemicals, they not sure what E85 is, but they can sell you Pure Ethanol, E95/5 @ R12.50 p/kg, though liquid form, 167KG`s is the drum sized with R130 drum deposit
Thank you for the input guys, I will try and get a hold of the above mentioned companies. @ Twins, I am looking to run E30 - E40 at first to get a feel for it, I have the flex fuel wires installed so I should be good for E50 down the line. :=):
No need for progressive (e's) if you have the flex fuel.
Take 8 liters of ethanol (e95) and mix with 12 liters of pump fuel and put the car on map 5 and have fun. If you run meth put it on map 3.
Once that is finished...increase to 9 liters of ethanol e95 and 11 Liters of pump fuel. Dont increase the ethanol to more than 9 liters unless you have the BMS flash installed.
For an even more aggressive mixture:
Premix the pump fuel with NF concentrate or use 98 or 100 octance racefuel instead of pump fuel and mix those bad boys with the ethanol as per my above suggestion.
Lastly, ethanol does not mix well in the tank. Consider mixing it before pouring it in the tank.
