SP33DYV said:Battery Centre supplies to BMW Dealers. I got an OEM BMW battery from them. Has all the BMW logos. Looks exactly like the original BMW battery. That was alomost a year ago.
Raybimmer said:The OE battery is made by First National Batteries in East London :thumbs: . It is the same as the batteries supplied to battery centre , colour may be different in some cases ( White -OE , black -aftermarket )
Also check for Varta ( May have 24 month guarantee )
abmi0000 said:Raybimmer said:The OE battery is made by First National Batteries in East London :thumbs: . It is the same as the batteries supplied to battery centre , colour may be different in some cases ( White -OE , black -aftermarket )
Who keeps Varta? Don't think that I have seen this brand anywhere. :dunno:
nick said:abmi0000 said:Raybimmer said:The OE battery is made by First National Batteries in East London :thumbs: . It is the same as the batteries supplied to battery centre , colour may be different in some cases ( White -OE , black -aftermarket )
A company called Deltec has Varta batteries 011-2188020 thats the head office i think, i buy from them quite often.
Jacques24 said:Varta is an imported European brand, very expensive (just replaced my Discovery at R4000), Varta is the only battery that produces the required output to run all it's electronics.
Tried the biggest Willard 658, but the car battled with gear changes and the air suspension.
Take it from me, these electronics on the car is full of crap, go OEM or at least the exact specs (hA & CCA ratings)
My Discovery OEM is a Varta 90aH with 950 CCA (Cold Cranking Amps), tried the Willard 95aH with 850 CCA, problems with the D3 with the Willard:
1 Cannot engage low range gearbox
2 The HK sound system's amp does not switch on
3 Air suspension can not raise to it's full off road mode
:thumbs:
Raybimmer said:Good luck , hope it lasts . Raylite brand ?
