zaleonardz
Yep,
But then you will need a hi/low converter as well.
In order of upgrade... do the foloowing as I assume your on a budget like the rest of us.
1. Upgrade the front splits with something decent (MBQuarts, Hertz, Focals) in standard location using standard wiring and amp
If that does not do it for you.
2. Buy decent 4 channel amp (Audison, RF... WHY) with a fuse kit, decent hi/low, decent wiring kit, and replace the cables running to the front splits, and tap the rears in... this will be chalk and cheese.
3. That should sort your midrange very very nicely, if you then want low down, get another amp , and fire a 10 or a 12" through the ski hatch or port your rear shelf...
