If the motor swings it shows the battery is ok .Any alternator trouble leads to a discharged battery . You then either need spark or fuel .
If you can get to the fuel delivery pipe and loosen it brfore it goes to the injectors and have someone swing the motor while you point the pipe into a container and see if fuel comes out .
If the timing is out then yes the car will not start. I'm not sure though that if the guide is broken if it will affect timing that much. Well you know who I'll recommend for the fix then.
Again all the best for the fix. Not nice when your car breaks before Eid and there is so much other stuff to sort out also :sorry:
