Alain said:Ok so is that 299 wkw? What is that in HP? I'm glad to see she is back :coolShake:
I see at this particular dyno they using 38%.Ja tell me about the correction factor. But im using it for before and after only. The actual figures dont mean much to me. Will see what it does on the road instead.gavsadler said:Nice Andy,
Dare I start a new debate about Dynos and correction factors?I see at this particular dyno they using 38%.
It doesn't matter really as long as you use the same dyno going forward to measure the changes.
I also noticed the graph only goes to 6500rpm. Any particular reason for this?
Kimeran@TheFanatics said:I heard of a C63 that was requesting to have a closer look at a S/C E46 M3, let me know if you know of one :fencelook:
Kimeran@TheFanatics said:Apparently this C63 also has a limiter in place, so that's going to be a problem :roflol:
