E46 BI-XENON PROJECTOR RETROFIT KIT
Sankekur said:
moranor said:
Sankekur said:
Well from my experience the light output out of a projector + halogen bulbs is really poor, worse than with normal reflector type lights.
were you using the right bulb for the projector? because the light spread from the bulb into the unit is very important...
Yup
im not sure it will be worth it for me then :(
chrisc
I am interested, but would like to ask you some questions first.
Is the light output of these any greater than the 55 watt halogen lamps fitted? The reports I have seen are a bit vague
What is the shipping cost to Cape Town?
vishal@somaitech
the light output is 35W and your wiring harness is designed for 55W so you are safe here.
overnight shipping to cape town is R80 for this box of goodies via speed services couriers.
thanks
Is there anything like this available for the E90 pre-LCI halogen housing? I know I'm taking a shot in the dark here as I've searched with no joy, but maybe, just maybe your answer will be yes.
vishal@somaitech
sorry bud, there isn't. this is due to the fact that it is almost impossible to remove the lense to install anything inside. you will have to buy an aftermarket set with the projectors already installed inside. then you would still need a xenon HID kit.
Thank you for confirming my fears :cry:
Will get the HID kit from you hopefully next month.
vishal@somaitech
PrevanP said:
Visual, do you have any pics of the kit fitted to an E46 headlight?
KAKA is about to make the deposit tomorrow morning. hopefully he can post some pics of the build. i will check around but there are plenty of these on the e46fanatics.com site.
lekker.
kabal
colour shift of this projector with a 5000K morimoto H1 bulb that I used in my bike
[video=youtube]
cutoff (poor pic)
osiris
Are these still available? was it the only set you had? and will it retrofit into an E36 headlight housing?
Sankekur
They should actually fit the e36 as well, and you can make them work with or without the shrouds. With the shrouds will give you a more modern look, and without will keep the OEM look.
vishal@somaitech
you are quite correct there bud. i have a set of projectors left but these are hithout the shrouds. are you interested?
osiris
ok hold onto the projectors for me, once the shrouds arrive ill take them off your hands. :) just pm me.
