E46 330i K&N CAI really worth it?
Is it worth the cash?
  • Yes
    Votes: 5 55.6%
  • No
    Votes: 3 33.3%
  • Other
    Votes: 1 11.1%
  • Total voters
    9
Kish2604
Administrator
Found the ffg write up on a CAI system over 30k miles... The vehicle is not a BMW but its still very relevant...
http://www.lastgreatroadtrip.com/fjcruisermods/long-term-report-kn-cold-air-intake/
Long-term Report – K&N Cold Air Intake
We all get excited by our new mods and tell everyone we know how its the best (fill in product name here) on the market and we explain all the reason we choose product X. But over time does that glowing praise fad, or are you still pleased with your purchase? This report follows a year of use in all sorts of conditions, and reflects our real world experience with the K&N CAI for the the FJ Cruiser.
We replace the Toyota FJ Cruiser’s stock air intake with a K&N cold air intake (CAI) about 30,000 miles ago. The decision to make this mod was based on the horse power gain claims and our desire to beat the dust and debris associated with the dirt and gravel roads of expedition travel. We picked up the K&N model 63-9030 cold air intake for the Toyota 4.0L engine.
K&N states “our 63 Series Intake Kits or AirCharger® Intakes are built for many different vehicles and represent a dramatic improvement over a K&N O/E replacement filter alone. These intakes use only non-metallic rotationally molded tubes that can reduce intake air temperature and decrease intake sound over a metal tube. Restriction can exist BETWEEN an air filter and the engine reducing the benefit of a K&N Air Filter. The weakest link in the airflow “chain” robs a vehicle of its natural horsepower. Often that weak point is the factory air path leading to the Engine. K&N Air Intake Kits virtually eliminate air path restriction by replacing the air filter and the entire air path to the engine. The aerodynamically engineered tube drives a massive amount of air into an engine, which translates into POWER.”
According to K&N we should have seen a horse power increase of 11.95hp @ 4785rpm (63-9030_dyno). And while our rig was not put on a Dyno to validate the increase we felt a gain and certainly heard the throaty sound of air rushing in.
The installation is simple for anyone who has replaced their own oil or changed a stock air filter. The kit came with all the parts and easy to follow instructions. The bigger, and I do mean big, air filter is washable and reusable allowing you to save money on filter replacements and increase air flow.
K&N states “All filters are constructed with ultra-strong molded pliable rubber flanges which absorb vibration and allow for secure attachment” and this is were we saw a major problem. The weight of the air filter hanging off the intake mount combined with the vibration of the rig as we cruised over washboard back roads (200 to 500 miles a day of washboard gravel and dirt at speeds of 40 – 55 mph) caused the filter to rub against the rigs body. This rubbing caused the filter to wear a hole through its wire mess and polished off the rig’s paint and primer below. At one point the filter vibrated completely off the intake tube despite a adjustable screw-down band clamp that came with the CAI. We did manage to correct this problem with some zip ties that secure the intake tube to the heat shield, adding support for the filter and lowering the amount of vibration cause the heavy filter.
The other drawback we found is that although the K&N CAI comes with an air guard designed to shield it from the hot engine bay, it is less than an ideal fit. Unlike TRD’s CAI which encloses the air filter, K&N’s is much more open with hot air flowing in from around, underneath and above the shield.
Bottom line, would we do it again… No! Although the K&N CAI works well enough, the lack of air control and the filters desire to jump off the intake tube leads us to want a new CAI.
All CAIs trade some filtration capability for more air flow and the oil sprayed onto this type of filter has been blamed for muck on the MAF (mass airflow) sensor. But based on discussions with other owners, next time we’ll try a TRD CAI. Of course than we would have to have a long-term report on TRD’s CAI. Think TRD wants to donate their CAI to the cause? We’ll See.
v1p3r
ChrisBrand said:
Diablo Jnr said:
For the sound alone, its worth it...
+1. If you want that I6 to amplify then you will love every second of it. Just don't expect huge gains but it is alot of money for just a good sound.
I have one in my car. Got off Gumtree for R1500 and loving every second of it
I can testify to ChrisBrand's car sounding befok. :rollsmile:
Yuben
Senior Moderator
I'm of the opinion that the oil from the filter will eventually stuff up the MAF resulting in a costly repair. Hence me personally would stay away from any performance filters
YUBEN said:
moranor@axis said:
I still won't chance it. Much research would have been done to design the OEM filter so why interfere with a winning formula...
Research is ongoing so things change... OEMs are fitting oiled filters to their cars... the e90 BMW performance air filter has an oiled filter many other German brands are doing the same...
K&N dipped a maf sensor in air filter oil and cleaned it... once cleaned it worked 100%
