E46 330i 5spd VS E46 330i 6spd
Iceman007
What are the Differince? I have heard the 6spd has more kw?
can some one shed some light on the subject :idea:
firaz
Hi Ice!
I've owned a 2002 5spd individual and currently have a 2004 6 speed!
The power output is rated @ 170kw for both models, however the 6 speed does feel much quicker. I think it has to do with the gear ratios.
The 6 speed I find is much lighter on fuel, @ 120 in sixth the engine spins at around 2500rpm. I average about 9l/km and my reserve light comes on after covering 650km.
I'd say 75percent highway driving and the rest in traffic.
Hope that helps.
Regards
Iceman007
firaz said:
Hi Ice!
Hope that helps.
Regards
Thanks :thumbs:
Raybimmer
IMHO both use the same engine there are differences in the gear ratios . December 2000 Car magazine 330i 5 speed road test :speeds at 6500 rpm , 1-61 , 2-104 , 3-155 , 4-209 , 5-259 ,doing 39.8 km/h per 1000 revs .gear ratios : 1-4.21 , 2-2.49 , 3-1.67 , 4-1.24 , 5-1.00 with diff 2.93 .
Car mag Sept 2003 : 330i 6 speed . Speeds at 6500 rpm : 1-57 , 2-98 , 3-148 , 4-200 , 5-246 , 6-289 with 6th at 44.54 km/h per 1000 revs . Gear ratios are 1-4.35 , 2-2.30 , 3-1.66 , 4-1.23 , 5-1.00 , 6-0.85 with 3.07 diff ratio . Both had 225/45 x 17 tyres .5 speed did 250 in 5th at 6277 rpm , 6speed did 255 at 5726 revs .
Hope this helps .
when i did a six speed conversion and ratio swap on my car i saw a huge difference in fuel consumption and performance...
if i could i would fit a 7 speed and drop the ratio even more :rollsmile:
Iceman of you looking at getting a 330i i would definitely get a 6 speed...
Iceman007
Its A friend of mine he is in the market for one, and looking around:thumbs:
