E46 330d buying advice
LPM320
Hi Guys.
Going to have a look at a 04 330d Manual. Anything I should look out for over and above the usual e46 problems. I know that the petrol cooling systems are on the weak side. Are the diesel's the same?
Thanks....
msm
IIRC, the coolant expansion tank (which usually cracks) is the same in the petrol and diesel. However, since the diesels run cooler, they give less problems.
XMAX
Do eeet.
The coolant expansion tanks should be changed. At R850 from goldwagen, its not an expensive maintenance part.
The biggest problem with the e46 330d was the autobox. The manuals are awesome.
Also, with that being an 04 model, it should have the 150kw engine. Will be pure awesomeness. But just remembver that its gonna drive very differently from that 328i.
P1000
If it is a six speed, and condition is good, pull the trigger. Just remove the swirl flaps and replace the crankcase breather as soon as you get it.
LPM320
Thanks for the advice gents.
Will update after I had a look at it.
@XMAX: Yeah it is quite different from the 328i. Drove one a few months ago. It hauls.... like a flippin freight train...
XMAX
with software imagine the possibilities.
i see lots of fun on the s bends... The DSC will go mad...
Make sure the car is in good condition, mechanically and bodywise. But I know you, so I dont need to say that.
good luck with the buy.
LPM320
Oh my word... The car was a total dog. Its clear that the previous owner didnt care a damn... Shocking how dealers can even stock cars like that. . . Hard leather, hoodlining falling, misaligned panels, accident damage... The list goes on and on...
XMAX
Dude, glad u not getting that aboration. Its amazing how dealers can mislkead people about cars. Say its immaculate and make u waste ur valuable time to see the car.
Let's hope that other project comes through.
Andy1GP
Drive a decent manual and auto to get a feel for what they should sound and pull like.
I have a manual 330d and it doesn't pull as it should. Someone had a look and it's got vacuum leaks. Haven't spent time locating it yet. Was scared that the turbo was going.
Normally they still have original shocks and control arm bushes on them. Check them.
Pricey parts are clutch+flywheel and injector/glow plugs and turbo when they do go.
Someone on the forum has an extensive turbo rebuild thread that you can look into.
As far as clutch+flywheel goes speak to racing snake and Gizmo. They organise great prices and will do the work for you too. Top notch guys :thumbs:
osiris
This is definately one of the best BMW's I have ever owned! I have the Auto and it really does give a beautiful drive and very responsive! When you put your foot down it goes!
When I got the car it still had the catalytic converters in it, and had quite a bit of turbo lag, I removed the cat and put a 63mm down pipe and its a whole new machine! All the little sounds it makes from the turbo are now audible and sounds awsome, The consumption also went right down! All I have to do now is software! I also did the EGR delete mod, which further improved consumption, and much less smoke gets pushed out the back when I put my foot down now!
I always hated Diesels and thought because of the low RPM that they would be a terrible drive, But with the Steptronic box the drive is incredibly smooth, the shifts are almost seemless, if you turn traction conctrol completely off and put the car in manual mode its a frikken monster! and this is with stock software! I can only imagine what this car feels like when its pushing over 500nm of torque on the wheels!!
Now I know there is allot of negativity towards this cars autobox! but from what I've read there are plenty mixed reviews on it, some people out there have mapped their auto's to push over 700nm and drive the car for years with no problems, and very few have stated that their boxes have actually broken but most have said that the box give shit once you change the Automatic transmission Fluid which is rated by BMW as a life time fluid so should never need to be changed.
I also think that its down to how you drive the car, if you drive it like a monkey everyday and tramp the accelerator in 1st in manual mode when the car is mapped which puts immense amounts of torque on the box then I'm sure it will break sooner than later too! a good Tuner should be able to map the car in such a way that the bigger amounts of torque come in 3rd gear and above instead of 700nm+ in 1st, which will not only be dangerous for your box but for drive shafts etc etc too!
Anyway hope this helps, just thought I would give my 2c on the subject!
