E46 325i Exhaust Sound
Epoc
Hi All,
Is it possible to make my 325i sound like a 330i? I want the deeper sound that the 330i makes but do not want to put an aftermarket exhaust on cos that will change the entire sound characteristics, unless I am wrong.
If I had to fit the 330i exhuast on my car will that work? Does the 330i header make a difference?
Could it be that because the 330i is a 3.0 litre and thus not possible?
STREETRACER
Bud the diameter of the 330 is not that much bigger so you will end up sounding around the same! Get two bosal decat boxes first which will improve performance and maybe give you the sound you are looking for!
The TNT free flows sounds awesome on BMW's! Gizmo just did TNT branches on his 330i and it now sounds not far off from an M3!
Rapido WP
Epoc said:
Hi All,
Seeing you in JHB get a back box from Rob Green - mine sounds awesome. Make sure you re-install the butterfly flap back into one of your new tail pipes though.
