AndrewPF said:Howzit bra
I'm in CT unfortunately. Car was running fine before I stripped it barring a bit lazy on pull away and when cold. Everything connected stripped again and double checked. Checked fuses etc. Thanks for the offer
Spiro said:Hey bud, let me know if you in jhb I can try and assist , diags wise,
Have you checked your icv if it's connected ?
danieljames said:So she's swinging over just not taking? Are your plugs wet?
danieljames said:Then try a stronger battery. I had an issue on my e36 and after two weeks of searching I tried a brand new big a$$ battery and she fired right up. Remember swinging a starter draws a lot of current from the battery and can deplete it quickly.
Worth a try. You've got nothing to lose. Keep us posted
Also check all earth straps
AndrewPF said:danieljames said:Then try a stronger battery. I had an issue on my e36 and after two weeks of searching I tried a brand new big a$$ battery and she fired right up. Remember swinging a starter draws a lot of current from the battery and can deplete it quickly.
Feedback.
After exhausting all avenues and doing a compression test ended up stripping motor. Found intake cam to be a tooth in retard that could be the cause of all my problems from day 1 with this car...laziness, flat spot etc. going to put rings and bearings anyway while it is open see what happens then. will post again when assembled
e46 2004 320i M54 . Thanks you are correct. It opens once you start cranking it. Seems I have a fuel problem. Fuel is there but not enough pressure. Thats all I can think of nowGPGrobler said:Which model is the car?
I doubt it if my car will do it, because mine is the 2002 f/l model so there is no cable physically linking the pedal to the throttle body as with the M52 engine where the throttle body was still operated with a cable. Anyone, please correct me on this if I am wrong: With the M54 the throttle body only responds to input from the pedal once the car has started?
Replaced fuel filter and eventually got it started again with a hell of a missfire. Got it on the reader 3 coils dead. got others started ran fine then after 20mins started to misfire again. :smashScreen::smashScreen::smashScreen:GPGrobler said:Have you changed the fuel filter yet? My car bogged down at +/- 4000 rpm in third before I replaced it, now it revs smoothly through all the gears.
After all that a flippen dodgy battery.AndrewPF said:Replaced fuel filter and eventually got it started again with a hell of a missfire. Got it on the reader 3 coils dead. got others started ran fine then after 20mins started to misfire again. :smashScreen::smashScreen::smashScreen:GPGrobler said:Have you changed the fuel filter yet? My car bogged down at +/- 4000 rpm in third before I replaced it, now it revs smoothly through all the gears.
