Hi guys, I'm at my wits end with my E90, (manual) I'm having issues with my car starting. It starts like normal and when I switch off it just won't start again. Sometimes it will start after I let it stand a while but that's not always the case. Out of frustration one day while the car was on, I started playing around with the gears and to my shock while moving it around into the gears it started up. It sounds crazy! So before i switch the car off i put it in gear, this seemed to help and I was a bit relieved but now that's not working either...
Sometimes i just pull the car out of the garage and switch off then it just won't start so its not because its overheating or something needs to cool down. Now i have to kick start it. My mechanic can't pick up a fault and says it could be 1 of 3 things. I rxplained all ths to him even about the gears and i think he doesn't believe me. Also when I take the car to him switch it off to show him, then it starts Is there any advise? I can't replace 3 things....
