E46 320 - BATTERY LIGHT PROBLEM
Prev
Administrator
Can somebody help to diagnose this problem.
Whilst driving home from work the other day, I noticed that the battery light came on after a few km's and then at the traffic light near home it went off. I went home and parked the car.
Today, when I got home, I started it and all seemed fine. So I let it idle for a while and then revv'd it a bit and noticed the battery light came on for a second and then went off. Every time I revv'd past 3000 it came on and then went off as the revv's dropped. I also notice that the car has a bit off a vacuum noise when pressing the accelerator. I made a video with my BB which shows the battery light problem but you cant really hear the engine noise
Any ideas?
plabise
Had the same issue but I was told its the alternator going, then decided to check my battery found out my battery had some dead cells, then replaced the battery and the battery light went off.
Prev
Administrator
Hope its just a belt slipping or even the battery and not the alternator
well from the vid i dont think its the belt you would surly hear it quite easily if it was slipping
Coisman had a vacuum cleaner noise that turned out to be the alternator maybe ask him about it :) maybe he just changed the regulator and that fixed it... think the regulator is under R500 if i remember right so that would be way cheaper than a new alternator :rollsmile:
Prev
Administrator
:thumbs: will wait for Cois to comment
quiet a mission to get to the alternator :cry:
S
SP33DYV
Regulator is over a grand and you can only get from the dealerships and certain auto-electricians.
dont think you right about the price but i dont have any proof ether... it goes for less than $50 online though for the oem Bosch product... have you tried Bosch diesel electric?
Prev
Administrator
Took the regulator out on Saturday but could not get a replacement at any of the local spares outlets. Checked with BMW this morning at it is R1857 incl VAT in Durban :cry: My car has a Valeo alternator so I need to find out who the Valeo agents are
Prev
Administrator
Could not wait any longer so I ordered one from BMW. They gave me a small discount and I ended up paying R1670 incl VAT. This is what the bugger looks like (old part).....new one will be here on Thursday
Inner
Outer
Its also fairly simple to remove.
1) Disconnect the battery
2) Take off the airbox & MAF
3) Disconnet main cable from alternator - 17 socket
4) 2 bolts holding alternator cover - 7mm socket - requires short extension due to space around bolts
5) undo alternator cooling vent pipe connected to the cover - simply pull loose
6) another 3 bolts - 7mm socket - to undo the regulator and she is out
Space is a small issue though as it is quiet cramped in that engine bay
Prev
Administrator
Well now I am pissed off and stumped......changed the regulator but the alternator is still not charging the battery.
Does anyone have any suggestions?
talk to one of the durban fanatics with an e46 and swap batteries... if the problem goes away you know what it is :)
Prev
Administrator
Doubt it is the battery......while the car was idling I took off the negative terminal and the car immediately switched off.
I put the battery on charge now and will let it charge for a few hours then check the voltage in the morn to see if it his holding its charge.
