Truvalu
NOW... LR door mechanism broke
Just opened the door, nylon pulleys are damaged and the "clip" running on the track is not holding the little pin that is in the cable.
I need to fix both LR and driver side door. Both making the same terrible creaking noise...
Managed to get the cable back on the pulley and window to top, holding the clip with a cable tie.
Switch disconnected
Any advice or contacts?
Can one use the guys in Ring-road Pinelands?
Leaving for Angola on Friday coming and need to get this fixed ASAP.
Thanks for the input.
Switch disconnected
