e39 M5
Peter@AEW
Just wanted to show you how a thermostat gets replaced on the M5.
The procedure is not very detailed as I lost some of the pics however most of you will get the idea.
444YYY
So the front 2 cylinders run at different temperatures from the rest?
.... This from seeing thoseintake 'snakes' facing the other way round..
Peter@AEW
More than likely...
Looks like 2,3,6 get the coolest air
Peter@AEW
DrKelso said:
a1exander said:
DrKelso said:
Green antifreeze. The bane of BMW existence.
It got flushed with BMW antifreeze
Although there is still trace of it
Opening up space for that magnificent white heap of junk standing next to the 740i i hope
I will not allow you to call my clients e46 M3s "junk"......well not untill such time as they have run big ends :)
Peter@AEW
DrKelso said:
Back to the car in question. Vanos just as big a problem on them as with the S54?
Unfortunately so......and in the case of the M5 you need to overhaul 2 units and 8 solenoids...not an inexpensive undertaking
DrKelso
Banned
Eish, add in all the other little foibles that will creep up as millage passes on and a E55 looks like a far more economical prospect.
Philip Foglar
Great stuff! :praise:
That's typical of the older cooling method - this is one of the reasons why BMW introduced the dreaded electric water pump cooling. The coolant flows through the engine from side to side (at least that's how it on the I6 models, not sure about the V8 models), so the temperatures are constant along all the cylinders.
faisel
Thanks peter for your assistance once again and your exemplary service.
Car runs well and handles like it should.
May have to sell soon as space a problem however gonna be a hard choice to make
BillyBob
Not half bad for someone with one usable hand....
You're the automotive equivalent of Def Leppard's drummer... :rollsmile:
faisel
Be careful work taking peter twice as long hint hint the bill:rollsmile::rollsmile:
Ratslaaf
That's a pity Faisel, as I've given this car a longing look a few times. She does present nicely and is in the correct color. My wife will, however, kille me if I even wonder in this direction anytime soon.
Just a bit of useless info, but did Peter tell you how we swore to get that radio going again? For reference Fordknoppie, many many choice words were uttered by myself and Rhohit to get that radio working again, fixing parts that are now unobtanium. And when we let loose, Peter couldn't help himself and started swearing like a sailor with Tourette's just for effect as well :roflol:
