I doubt its the MAFs.
Bad MAFs make it lazy, but the induction sound will be normal.
You say the induction sound has changed?
A "blatty" induction sound is one (or more) of the CPSes.
(Camshaft Position Sensor)
Typically the exhaust CPSes fail, especially if they're still the originals.
Get the fault codes read before you spend money on sensors or MAFs.
But I'll bet it's a CPS.
There are 4 CPSes. Two per bank, one for the intake camshaft and one for the exhaust camshaft.
I had a failed Exhaust CPS.
Sherwin kindly read my fault codes for me, and it had logged the following errors:
11 - AVANOS2-Hall Sensor
162 - Synchronisation CS-Sensor 2 with KW
So you're looking for something about a failed VANOS Sensor, and another about a synchronisation problem between the CPS and the crankshaft.
(AVANOS2 = Auslass VANOS = Exhaust VANOS, of Bank 2)
Different systems will give you different error explanations.
If you're not sure, post the error codes here and we'll solve them.
