E39 M5 just dies while driving on freeway.
///MNM
Hi guys
It has been a while since I've posted anything on the forum due to work commitments.
While driving on the N1 yesterday afternoon, I decided to turn on the aircon and the car just stalled without any warning. I managed to get the car to the side of the road and tried starting it with no success. The car idles for about 2-3 seconds and just dies.
I'm not sure if turning the aircon on had anything to do with the car stalling or was it just co-incidental?
My mechanic came out to assist and concluded that it is the fuel pump. Is there perhaps a suitable replacement pump which I can use instead of getting one from the stealers?
I am not mechanically inclined but isn't there a relay or any other easier method to determine whether or not it is indeed the fuel pump? I really don't wanna spend money unnecessarily only to find that it is something minor.
Any assistance or advice will be highly appreciated.
Thanks.
ggrobler
///MNM said:
Hi guys
Thanks.
Let your mechanic check the fuel pressure it could just be a fuel filter that's blocked if the pumped died the car will not start at all (idle for 2-3 seconds).
zaleonardz
Silly question,
Have you checked that your battery terminals are tightened properly, and that your battery is in good shape..
///MNM
zaleonardz@DentDoctor said:
Silly question,
Hi Zaleonardz
First attempt to start the vehicle, the car idled for about 2 seconds and died. Checked if battery terminals were tight, and yes it was. Second attempt with foot flat on the accelerator the car just spluttered and died.
I will get the battery tested just in case?
///MNM
Problem solved, turned out to be a faulty relay and not the fuel pump. Thank you for the advice once again.
///MNM
telegamer said:
I had that issue on my old MK2 GTI many years ago....turned out to be a dry joint on he fuel relay
Hi Telegamer
Turns out this is precisely what happened to my car. Thanks.
spawn616 said:
do u stay in the south by anychance?and how do u let the wife drive the car if u are the same person?
Hi
I am from the South and NO the wife doesn't drive my car.:thumbs:
Redline said:
Shew,
You may be relieved, I would have had sleepless nights.
I am very relieved with the fact that I did not have to spend money on a new fuel pump. Moments like these that makes you appreciate being a member on this forum. Thanks once again guys.
spawn616
ah must of been some one else,car had some pretty exhausts on it,women drove it right but still not a womens car(not been sexest)
