My E39 540/6 went in for it's first oil service since I bought it, so I ask the agents to do a diagnostics on it at the same time.
Diagnostics reports the following, verbatim: "Worked through test schedule. Found Oxygen Sensor, crank vent & pipes & MAP cooling faulty. Quoted to replace."
On the report card, they say that "crank vent to be fitted first & then only further diagostics".
My question. What symptoms will I experience from the above faults? What will I find or feel while driving? Is the BMW quote of R 7,809.58 to fix worth it, or can this be a DIY project? Their cost includes, inter alia, R1,198.05 for a thermostat, R 1,132.52 for a "profile gasket", as well as R 1,021.73 for an "Intake Manifold" - amongst other rather pricey bits.
Can this stay as is, should it be repaired ASAP, what's it doing/causing, etc, etc.
Any help/advice out there?
Thanks.
Thanks.
