E39 540i electrical gremlin Help
Tauzty
Hi
I recently just got the centre support bearing/Shocks replaced and ever since the car got back it has been doing this very weird thing .
Once I switch off the car and remove the car key and lock the vehicle after 5 or so minutes the Alarm will go off and dash lights/brake lights will come back on ,everythings on the dash exactly like the key was inn.
Then I will put key inn and start the vehicle and switch her off again and lo and behold the Dash lights come back on and the Brake lights stay on as well of the vehicle.
I have replaced the final stage unit with a HELLA replacement and this still happens .
while the dash lights was on and brake lights I even pulled the plug that is connected to the ignition switch and this doesnt do anything as all the dash lights and brake lights remain on .:nonono::nonono:
what can this be gents , besides this the car is a dream to drive .
S1NGH 911
Get the car read and see what codes it throws, take it from there :thumbs:
Tauzty
Thanks will get that done this wkend . I hope it can be sorted out , I noticed the oil light stays on when key is removed then entire dash light and brakes lights lit up
